Retired_Member
Jul 31, 2022Cannot check firmware updates
Im trying to check A7000 firmware updates with genie software, it advances to 20%, and stays there forever ?
- Retired_MemberJul 31, 2022
But you didnt understand that i have been doing what you suggested in first place ?
Anyways, if this usb stick is allready abandoned by netgear, i wont bother anymore 🙂
Ty you for the suggestions and for replying.
A better option is to visit the support pages and to download any updates from there.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.The latest update was four years ago:
A7000 Software Version 1.0.0.15 (Windows) | Answer | NETGEAR Support
- Retired_Member
Im not looking software, your link is for genie software 🙂 Within genie software you should be able to update firmware..
I dont see any other way to update usb stick since it does not have its own web frontend or ui...
Did you read my message?
The way to update the usb stick is to download the software and run the program it delivers.
Try reading this again:
To Install:
Using the Download Link below, download and extract the new software to a convenient place such as your desktop.
Download Link:
http://www.downloads.netgear.com/files/GDC/A7000/A7000_V1.0.0.15_Windows.zipIn other words, it is the same process as just about anything you need to update on a computer.
If you need the Mac version, that is there too.
