yorkc
Jan 17, 2016Aspirant
can't access internet n900 wnda4100 - solid blue light
I installed my n900 wireless adapter and it worked fine for a while, then I would get Runtime Error! warning. I uninstalled, reinstalled standalone with the newest driver. Now it seems like it's inst...
JamesGL
Jan 20, 2016NETGEAR Employee Retired
Hi yorkc,
What is the OS of your computer?
Please try to uninstalll the adapter but disable first antivirus and firewall before reinstalling it. If same thing happens, install it on a different computer.
yorkc
Jan 26, 2016Aspirant
I already did this. No anti-virus or firewall is running. I don't have another computer to install it on just to check and see if it works. I did go purchase another just to see if it was a defective piece of hardware, but I get the same results so I'll be returning that second one to the store.
Any other thoughts?
- JamesGLJan 27, 2016NETGEAR Employee Retired
Hi yorkc,
To isolate the problem, we may need to use a different computer since it is the 2nd same adapter that you have tried. If you will return the 2nd one, try replacing it with a different model and check it again.
