Willnida
Aug 26, 2018Aspirant
Computer connects to router but no Internet connection
Hello everyone, I have had my netgear WNA3100 wireless adapter for about a year now, and everything has been working fine. But just recently, it started acting up, and now it is saying that it is con...
Willnida
Aug 27, 2018Aspirant
Ironically, the windows troubleshooter wont work no matter what i do. Any ideas?
michaelkenward
Aug 28, 2018Guru - Experienced User
What does "won't work" mean? Won't start? Finds no problems? How are you starting the troubleshooter?
The former suggests that Windows is broken.
If the network icon is visible in the notification area, right click Open Network & Internet Settings. Then WiFi and look at the Network and Sharing Center and you should see if the wifi says that it is a Private network. If in it is a Public Network Windows will block you.
Another way in is Open Network & Internet Settings > WiFi > Manage Known Networks > Pick your wifi network > Properties. Then you can toggle Public/Private.
