ratcher's avatar
ratcher
Follower
Oct 06, 2015
Connecting a Hopper to the internal WiFi.
I want to connect my Hopper to the WiFi wireless system in my house. The DISH website says use Netgear Model WNDA3100v2. It appears that this model is no longer produced. I can only find refurbished units or ones shipping from overseas. Is there a newer Netgear model that I can use to set up this Hopper?
Thanks
    • michaelnoldersr's avatar
      michaelnoldersr
      However on the package it doesn't state whether or not it is a "V2 or V3" as would be the case for myself.  I went and got the only version they had at the store and it states just that on the boxes WNDA3100 but nothing else....So that don't help much either...
      • TheEther's avatar
        TheEther
        Guru
        There should be no functional difference between V2 and V3.
