sheds75
May 24, 2018Follower
connection/pawwsord issues
I have a WN3000RP wireless extender that was previously connected to my SKY breadband, we have just moved onto a BT SMART HUB and whilst the extender connects to the wireless signal I can not connec...
michaelkenward
May 24, 2018Guru - Experienced User
sheds75 wrote:
I can not connect any devices with the BT password.
What BT password is this? Wifi? Internet?
They aren't the same.
Have you reset the wifi extender and set it up from scratch? You need to get it to forget that it was ever connected to the SKY box.
