Eddie365
Jun 16, 2017Follower
Convert printer to wifi
Which product do you recommend to convert a Kyocera TA4550ci MFP to a wifi device? Currently it is being used via USB cable in a wifi environment.
- Jun 27, 2017
Hi Eddie365,
NETGEAR USB adapters are compatible with Windows based computers and does not work other devices. If your printer has ethernet port, you can try WNCE3001 or WNCE4004.
JamesGL
Jun 27, 2017NETGEAR Employee Retired
Hi Eddie365,
- JamesGLJul 10, 2017NETGEAR Employee Retired
Hi Eddie365,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
