Eddie365's avatar
Eddie365
Follower
Jun 16, 2017
Convert printer to wifi
Which product do you recommend to convert a Kyocera TA4550ci MFP to a wifi device? Currently it is being used via USB cable in a wifi environment.
  • JamesGL's avatar
    Jun 27, 2017
    Hi Eddie365,
    NETGEAR USB adapters are compatible with Windows based computers and does not work other devices. If your printer has ethernet port, you can try WNCE3001 or WNCE4004.
