gcharlesb
Jul 29, 2015Guide
desktop-upgraded to windows 10- usb dongle setup incomplete
dongle not working after update to W10. says setup incomplete. tried reinstalling, and rebooting. still doesn't connect. worked fine on 8.1 :(
UMDTERPS
Jul 31, 2015Apprentice
Same problem. I have a desktop with windows 7 and I upgraded to 10 because other said it worked. NOPE, BIG MISTAKE. Dongle worked fine before the upgrade and now is bricked afterwards. When I plug in the dongle nothing happens. When I try to load the software, the install manager freezes. I need to find a ethernet one.
Netgear, you had plently of time to create a driver for Windows 10. Shame on you.
- Babylon5Jul 31, 2015NETGEAR Employee RetiredWhat model of adaptor do you have? In the 'Recommendations' area to the right of this screen you should see a number of threads where people have devices working fine with Windows 10.
