gcharlesb
Jul 29, 2015Guide
desktop-upgraded to windows 10- usb dongle setup incomplete
dongle not working after update to W10. says setup incomplete. tried reinstalling, and rebooting. still doesn't connect. worked fine on 8.1 :(
UMDTERPS
Jul 31, 2015Apprentice
Same problem. I have a desktop with windows 7 and I upgraded to 10 because other said it worked. NOPE, BIG MISTAKE. Dongle worked fine before the upgrade and now is bricked afterwards. When I plug in the dongle nothing happens. When I try to load the software, the install manager freezes. I need to find a ethernet one.
Netgear, you had plently of time to create a driver for Windows 10. Shame on you.
Babylon5
Jul 31, 2015NETGEAR Employee Retired
What model of adaptor do you have? In the 'Recommendations' area to the right of this screen you should see a number of threads where people have devices working fine with Windows 10.
