Leggo0
Apr 10, 2018Follower
Device undetected after computer wakeup
Recently, after going to use my desktop after waking the computer up from sleep, my A6210 will be undetected. The only way I have found to fix it is to unplug the antenna from the docking base on my ...
itsjustfrank
Apr 26, 2018Aspirant
I have the same problem. This also occurs on some restarts, but happens every time the PC resumes from sleep. The only solution is to unplug the adapter and plug it back in. Depending on where the device is located this can be a nuisance. I'm guessing since this doesn't keep the device from functioning - it is more of an extreme annoyance that it doesn't work properly - this is probably why Netgear is ignoring this problem.
I have also checked power settings to ensure that Windows is not powering off USB devices and that wireless adapters are set to max performance.
JamesGL
Apr 30, 2018NETGEAR Employee Retired
- JamesGLMay 03, 2018NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- itsjustfrankMay 12, 2018Aspirant
I thought I had made it clear in my post that I tried this solution. Apologies if I hadn't. This does has no effect on my issue. When resuming from sleep the device is still unresponsive.
- JamesGLMay 31, 2018NETGEAR Employee Retired
Hi itsjustfrank,
Have you tried it on a different computer?
