cmlong's avatar
cmlong
Follower
Apr 28, 2016
Downloading software/setup for Wireless AC600 Adapter
I keep getting a message when it's trying to install the drivers that drive j is an invalid drive.  Why is it trying to install here, and how can I change the location?
1 Reply
  • Well, have you tried right-clicking the CD then clicking Explore? That will help.
    If you downloaded a .exe try downloading 7zip at http://www.7-zip.org/ then right-click after the install on the .exe you want to extract and choose 7zip then choose extract.
    Hope that helped! :smileyhappy:
