Balloo69
Jul 07, 2016Follower
Driver for Mac OS
I was told at Bestbuy that this WNDA3100v3 wireless adapter would work for both PC and my Macbook Pro. It did okay on the PC but we no longer need to use it there to boost the wifi signal. I tried in...
- Jul 12, 2016
Hi Balloo69,
The system requirement for the adapter is for Windows based OS only.
JamesGL
Jul 12, 2016NETGEAR Employee Retired
Hi Balloo69,
CVR
Jul 30, 2016Aspirant
- CVRJul 30, 2016Aspirant
Hi!
Would this link work for mentioned adapter? (A6210)? I have been experiencing similar problems concerning OS software that it didn't link up together or Macbook doesn't even recognize the adapter.
Please and thank you!- JamesGLJul 31, 2016NETGEAR Employee Retired
Hi CVR,
The drivers of this adapter is only applicable for Windows based OS system. It is indicated in the system requirements for the adapter.
JamesGL
Community Team
- CVRJul 31, 2016Aspirant
Hi there James,
I looked it up and indeed, this one isn't competible for OS software. Can you reccomend one from Netgear that could work on both platforms?
CVR
