KiMight
May 19, 2016Aspirant
Drivers crash in windows 10
Hi, I've had WNA3100 for some years now and after updating to Win10 I've been having constant problems with the modem. First and foremost the drivers crash at about 10 minute intervals under load...
KiMight
Forgot to mention I have around 5000 events like these:
Advarsel 11.05.2016 23:38:31 NDIS 10400 Ingen
Advarsel 11.05.2016 23:38:33 NDIS 10400 Ingen
Advarsel 11.05.2016 23:38:27 NDIS 10400 Ingen
Advarsel 11.05.2016 23:38:29 NDIS 10400 Ingen
Tilbakestillingen av nettverksgrensesnittet NETGEAR WNA3100 N300 Wireless USB Adapter har begynt. Det vil oppstå et midlertidig brudd i nettverkstilkoblingen mens maskinvaren tilbakestilles.
Årsak: Nettverksdriveren ba om at den blir tilbakestilt.
Dette nettverksgrensesnittet har blitt tilbakestilt 2853 gang(er) siden forrige initialisering.
Translated:
Reset of the network interface NETGEAR WNA3100 N300 Wireless USB Adapter has begun. There will be some temporary stops in the network connection while the machineware resets.
Cause: The network driver asked for it to be reset.
This network interface has been reset 2853 times since last initialization.
JamesGL
May 26, 2016NETGEAR Employee Retired
Hi KiMight,
Make sure to use software for Windows 10.
http://downloadcenter.netgear.com/en/product/WNA3100#searchResults
- NJDougMay 26, 2016Guide
James I do not know if you are aware but I have a case open that no one is looking at .... It Clearly shows the a6210.sys file is crashing windows 10 on a regulare base's ..... With the a6210 the Driver is faulty and it does not mater what you do it does not solve the issue ....
- JamesGLJun 03, 2016NETGEAR Employee Retired
Hi NJDoug,
I believe your case is now being handled by support team. Please continue to work with them for resolution.
- NJDougJun 24, 2016Guide
JamesGL I can tell you for the 6210 adapter they have no clue why it is crashing .... NOTHING they sugest works ... I feel bad for Mod's for this forum cause there is NOTHING you can sugest that will work I have been over a month trying to work with them and you do not deal with someone who can help you deal with a middle man who ttells you there ideals and then takes your response back to them and it is like the phone game .... I have an Alfa Wifi usb Adapter with the same chip set and it work %100.... Why can a diffrent company have the same chipset work ing and Netgear can't ?????
The Alfa AWUS036AC is the product I bought on Amozon for half the price ...... Netgear this is Sad ..But I can say my NightHawk Router rocks perfect ...
