payt
Sep 30, 2022Follower
Extender Suddenly not Connecting To PC
Hello, I have had the netgear wifi extender ex2700 for a long time now. I have it plugged into my wall and I have an ethernet cable connecting from the extender to my pc. This has worked for a long ...
Oct 01, 2022Guru - Experienced User
Do you have a phone to see if the wireless is working?
The EX2700, if setup properly, the ethernet should work without user intervention as it doesn't have an AP mode.
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
