domenico33
Jan 25, 2016Follower
From Wi Fi to ethernet
Good morning all, pretty new in this community I have a question for you, finishing my new house (pretty full of domotics) I found out of a needs not hilighted before by the supplier, the need is to...
Babylon5
Jan 25, 2016NETGEAR Employee Retired
Could you tell us more about the device which creates the data, e.g. is it an Access Point, Wireless Router, WiFI client? Do you know the model number and manufacturer of the device?
Are you wanting to bridge that 40m distance wirelessly or using Ethernet cable. Will the device at the house be inside the house e.g. near a window?
aalexandrebeta
Jun 02, 2016Master
As far as I am concerned the eth cable will allways overpower WI-Fi!
My choice order is cable, wifi and PLC!
