gta_fan's avatar
gta_fan
Genie won't detect A6210
The Netgear Genie won't detect my A6210 on Win 10 (ever since I had to reinstall windows), I checked WLAN in services and it's running but the genie still won't detect and won't connect whenever I restart my PC untill I unplug the USB from the 3.1 port than plug back in (maybe I should try doing a fresh reinstall of windows)
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi gta_fan,
    Is the device still detected under the device manager? Look for the 802.11 AC WLAN card or the NETGEAR A6210.
    • gta_fan's avatar
      gta_fan
      802.11ac WLAN is and properties say This device is working properly.
      • JamesGL's avatar
        JamesGL
        Hi gta_fan,
        Please check your inbox.
