G_Pap
Feb 26, 2017Tutor
Hard Drive via Wi-Fi
Hello, I have D7000 as Modem / Router and my question is, can I use a Wi-Fi adapter to an Ethernet Hard Drive ? If so, I 'll be able to view the content of Hard Drive from my computer ? * As you m...
- Feb 26, 2017
Is there any reason the NAS needs to be in the living room? After all, it's Network Attached Storage. It's shouldn't matter where it's placed.
The WNCE4004 should work but there may be a significant performance penalty. Communicating with it may require going over Wi-Fi twice. For example, smartphone<-Wi-Fi->router<-Wi-Fi>NAS.
Viewing files depends on what is supported by the NAS. All of them can share files like a Windows machine. Many can also share via DLNA. And still others can share via server programs, like Plex or Kodi. You should consult the documentation for your NAS.
TheEther
Feb 26, 2017Guru
Your hard drive has an Ethernet port? In other words, it's a NAS (Network Attached Storage)? If yes, why not connect it directly to the router via Ethernet?
- G_PapFeb 26, 2017Tutor
Thanks,
I have the Router in distance from where Hard Drive is.
That's why I wonder if an adapter can do the job for me.
I searched a little on Google.
If I have a NAS can I use the adapter to my NAS then, to make it accessible from computer ?
Thanks.
- TheEtherFeb 26, 2017Guru
It's best to connect the NAS to the router via Ethernet. Ethernet is faster and more reliable than Wi-Fi. You can still access the NAS from your computer over the network.
