JoelBr's avatar
JoelBr
Have some question regarding the A9000
Hi
  1. Is 100Mbps max speed when using it in "injection mode"
  2. Can the device work in AP mode (or injection mode) in the 6GHz band?
Thanks :D
  • StephenB's avatar
    There is no AP mode.
    Netgear says nothing about injection mode, but the MediaTek chipset doesn't preclude it.  So it might work (or might not).  AFAIK there is no speed cap built into the adapter.
    • schumaku's avatar
      schumaku
      There are many other usage scenarios for these A9000/BE6500 devices beyond pure WiFi clients what Netgear does test and support.
      JoelBr​  MediaTek MT7925U (Filogic 360 / Wi-Fi 7 chipset supports monitor mode and packet injection on Linux using the upstream mt76 / mt7925u driver.
      Nothing beyond of what is part of the product data sheet is supported by Netgear.
      • StephenB's avatar
        FWIW, I knew that, but haven't used it for that myself.
        If someone here has, then it'd be great if they can chime in.
