JoelBr
Oct 23, 2026Aspirant
Have some question regarding the A9000
Hi Have some question regarding the A9000 Is 100Mbps max speed when using it in "injection mode" Can the device work in AP mode (or injection mode) in the 6GHz band? Thanks :D
schumaku
Oct 24, 2026Guru - Experienced User
There are many other usage scenarios for these A9000/BE6500 devices beyond pure WiFi clients what Netgear does test and support.
JoelBr MediaTek MT7925U (Filogic 360 / Wi-Fi 7 chipset supports monitor mode and packet injection on Linux using the upstream mt76 / mt7925u driver.
Nothing beyond of what is part of the product data sheet is supported by Netgear.
schumaku
https://lwn.net/Articles/939966/ does clearly state (since August 2023);
"This series adds mt7925, a new mac80211 driver for MediaTek Wi-Fi 7 (802.11be) device Filogic 360, which can support Station, AP, P2P, and monitor modes. Filogic 360 supports max 4096-QAM/160MHz radio operation at 6 GHz, 5 GHz, or 2.4 GHz with 2x2 antennas. This chip supports PCIe and USB bus type."
Investigating further on, does show that users are successfully use monitor and inection modes on the :
https://github.com/morrownr/USB-WiFi/blob/main/home/Recommended_Adapters_for_Kali_Linux.md
"The Netgear A9000 passes all monitor mode tests. It uses the mt7925u driver"
Worth following GitHub @ morrownr and investigate what is going on there ... JoelBr
There is no AP mode.
Sorry, there is ...
- StephenBOct 24, 2026Guru - Experienced User
schumaku wrote:
Sorry, there is ...
Not in the manual though.
- JoelBrOct 24, 2026Aspirant
Thanks 😊
Yea I use Kali 🫠
"The matte silvery finish adapter had its limits"
I have done some testing of mostly all possible parameters I could find.
I could not get 6Ghz AP to work (might be do to regulations)... only as client with router worked out for me :(...
I will look into morrownr
Thanks for all feedback 😀
