KellyKat3737
Dec 02, 2015Follower
Help Installation with AC1200 High Gain Wifi USB Adapter to a Smart Samsung UN60D6000SF
Help Installation with AC1200 High Gain Wifi USB Adapter to a Smart Samsung UN60D6000SF. Thank you and I hope I hear from someone, I've been on hold with Netgear over 30 minutes. Kelly
DexterJB
Dec 02, 2015NETGEAR Moderator
Hi KellyKat3737,
NETGEAR wireless USB adapters can only be used for Windows computers since it will require installing device drivers. I believe your Samsung TV will require a specific Samsung USB adapter as indicated on the user manual for it. You may refer to the link below for the user manual of your TV on page 81.
http://downloadcenter.samsung.com/content/UM/201103/20110324091218633/[ENG_US]GSATSCA-1017.pdf
Dexter
Community Team
