eberpit
Aug 01, 2016Follower
how can I connect my channel master dvr to wifi using my WNDA3100 (wireless-n dual band)?
JUST GOT A CHANNEL MASTER DVR AND HAVE AN OLD WIRELESS ADAPTER. CAN I USE THE 3100V2 TO GET WIRELESS INTERNET TO MY DVR? IF SO HOW?
JamesGL
Aug 07, 2016NETGEAR Employee Retired
Hi eberpit,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
- Y_BAug 16, 2016Aspirant
I have the same question except my USB adapter is from Channel Master for their DVR. I have a WNR2000v2.
The DVR shows it sees the router but cannot connect ( this is all done via the TV screen). The DVR will connect via cable.
I have tried auto connect, manual connect, have line of site to the router from the adapter, I added the MAC address from the adapter to the Wireless card accest list. I have researched for answers online and in this forum. I have done everything I think I could find with the exception of the use of a sledgehammer.
Any help would be very much appriciated.
I am using a Mac computer for access
- Y_BAug 19, 2016Aspirant
Help?.... anyone?? Hello??
- JamesGLAug 23, 2016NETGEAR Employee Retired
Hi Y_B,
Is the model number of your adapter WNDA3100? If yes, this type of adapter is intended for computers and not with DVR. You may need to check with the Channel Master if the device has been modified to work with DVR.
JamesGL
Community Team
