1976kjell
Oct 29, 2015Initiate
How to change channel in Smart Wizard
Hi Im new to this community and this is my first question I have a netgear WNA3100 wifi adapter and the last weeks my wireless network has been very unstable. Googled it found out that chang...
- Oct 29, 2015
The Wi-Fi channel used by the WNA3100 is determined by the Wi-Fi router or Access point that it's connected to. You would need to log into the router or Access point and change the channel, there.
TheEther
Oct 29, 2015Guru
ElkHair14
Dec 01, 2015Aspirant
I have four WN2500RPs. Got a way to put them all on a unique channel from the same router... would be a lot more versatile if it could be changed the other way around.
