1976kjell
Oct 29, 2015Initiate
How to change channel in Smart Wizard
Hi Im new to this community and this is my first question I have a netgear WNA3100 wifi adapter and the last weeks my wireless network has been very unstable. Googled it found out that chang...
- Oct 29, 2015
The Wi-Fi channel used by the WNA3100 is determined by the Wi-Fi router or Access point that it's connected to. You would need to log into the router or Access point and change the channel, there.
TheEther
Oct 29, 2015Guru
1976kjell
Didnt knew how to log in to a router, but googled it and logged in. Now I have access to the router, and I hope that choosing channel 11 instead of auto will help, to get the wifi more stable
Just adding the the IP-adress in the andress bar on the browser, then the log in page for the router will appear
Thanks
