Ro's avatar
Ro
How to change on a Netgear A6200 USB WiFi adapter, the region setting from US to Europe ?
Does anybody having a clou, how to change on a Netgear A6200 USB WiFi adapter, the region setting from US to Europe ?
(and uses the right WiFi channels) Or where does a Netgear A6200 USB WiFi adapter actually getting its region settings from ?
i did install (and uninstall) several software versions from v1.0.0.11 to v1.0.0.26 to the latest v1.0.0.35 without result (Europe region) but it does give the Europe region setting on an older Windows 95 OS machine. (so it is possible)
i do believe the Netgear A6200 it's getting its region information setting, somewhere from the local computer.
thanks for helping me, finding a solution.
  • the S O L U T I O N, where to change the region settings of your Netgear WiFi USB adapter
    -Control Panel
    -Region and Language
    -Administrative
    -Change System Locale
    -Change Region and Language Settings
    Many thanks to Wim van den Breekel, from Truecom, for finding this setting.
    -Control Panel
    -Administrative
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Ro,
    Welcome to Community!
    May I know where do you check the country/region setting of your adapter. please provide a screenshot.
    JamesGL
    Community Team
    • Ro's avatar
      Ro
      Hello James,
      Snapshots of a Windows 7 professional and a Windows 95 laptop Netgear A6200 in HP NC6730.jpg
      I bought this Netgear A6200 USB adapter, because it was advised by Fluke, the supplier of the site survey program AirMagnet.
      Kind regards, Robert Jan
      • JamesGL's avatar
        JamesGL
        Ro,
        Can you check if the softwares of your Windows 95 are set to Europe? It could be that the system of your computer is set to others.
        JamesGL
        Community Team
