pdshapiro
Apr 07, 2020Aspirant
How to get wifi adapter to select 5GHz band from router
Just installed ModelA6150 Wifi adapter in order to use 5GHz band on home Comcast router. But data rate on the connected PC shows as slow as before when earlier adapter was using noisy 2.4Ghz band. My...
- Apr 07, 2020
Not saying this is the case but if you have bandsteering on, it can take a bit as it determines how much bandwidth it uses and if it needs the 5ghz or 2.4ghz
pdshapiro
I've confirmed by checking my Android (Pixel) phone which is in the same location as the PC that it is working at 5GHz so the router must be selecting 5GHz for the phone. According to the link you provided (for which, many thanks), the router does this beam selection automatically. And yet, my PC ... using the new adapter A6150... seems stuck at the rate it was getting when limited to 2.4GHz. Why would this be?
Apr 07, 2020Guru - Experienced User
- pdshapiroApr 07, 2020Aspirant
I think you're right. I've suddenly started to get 5GHz type speeds, ~160Mbs, so apparently the router concluded that the new adapter would work better at 5GHz. As you say, it took a while, then just started working. Thanks very much for your help!
