ChristopheFRAN
Nov 19, 2015Initiate
Impossible to install ON NETWORKS - N300MA adapter under Windows 10
Hi, I've just installed Windows 10 and I try to use the Wifi "ON NETWORKS - N300MA adapter". When I click on the net to find the right driver for win10, I'm always redirected to the netgear web...
csheff
Jan 08, 2016Initiate
Hi Christophe,
You can download a suitable driver from the Microsoft Update catalog. It works on my PC on Windows 10 - might not be "supported" by Netgear, but it does work. Search for the following package:
on networks wlan n300 micro usb wifi adapter - N300MA
or this link should do it:
You need to visit it in Internet Explorer. There are two packages, one for 64 bit and one for 32 bit.
Hope this helps,
Cheers
Chris
