Ckelley
Jan 16, 2021Tutor
Laency spikes due to autoconfig going haywire. is there a permenant fix for this?
So I have had my this Wifi AC7000 adapter on my PC for about 3 months, first few weeks ran fine super fast speeds, actually I couldn't belive how fast this wifi was. I connect to a wifi router that m...
- Jan 17, 2021
Have you tried uninstalling it and doing a stand alone driver install on it?
Not using the utility?I've also seen some follow this guide: how to fix netgear disconnecting a7000, a6210 adapters - YouTube
with good results.
Jan 17, 2021Guru - Experienced User
with good results.
Ckelley
Jan 17, 2021Tutor
I have not tried a stand alone driver. So basically uninstall the netgear genie and just install a driver for the adapter. Ill give it a shot. I figured the autoconfig thing was part of the driver but its worth a try. Ill let you know.
