Ckelley
Jan 16, 2021Tutor
Laency spikes due to autoconfig going haywire. is there a permenant fix for this?
So I have had my this Wifi AC7000 adapter on my PC for about 3 months, first few weeks ran fine super fast speeds, actually I couldn't belive how fast this wifi was. I connect to a wifi router that m...
- Jan 17, 2021
Have you tried uninstalling it and doing a stand alone driver install on it?
Not using the utility?I've also seen some follow this guide: how to fix netgear disconnecting a7000, a6210 adapters - YouTube
with good results.
Ckelley
Jan 21, 2021Tutor
Well after a few days of using the stand alone driver it seems that it works fine. The latency spikes have stopped and I dont have to do anything special to have the adapter work properly after roboot.
A little diappointed that the software that comes with the adapter breaks the adapter. Netgear you should probably get on that.
Jan 22, 2021Guru - Experienced User
Glad you got it working!
Netgear isn't on these forums much but hopefully they see the these issues.
