pixturman
May 26, 2017Follower
Limited or no connectivity
I have a wg121 usb wireless adapter which I have used on another desktop before with no problems. I just got a new used computer that has xp sp3 and I wanted to connect the adapter to it so I downloa...
- May 30, 2017
Hi pixturman,
Possible issue is the driver is not compatible with the OS service pack and the also not compatible with security options.
JamesGL
May 30, 2017NETGEAR Employee Retired
Hi pixturman,
