pixturman's avatar
pixturman
Follower
May 26, 2017
Limited or no connectivity
I have a wg121 usb wireless adapter which I have used on another desktop before with no problems. I just got a new used computer that has xp sp3 and I wanted to connect the adapter to it so I downloa...
  • JamesGL's avatar
    May 30, 2017
    Hi pixturman,
    Possible issue is the driver is not compatible with the OS service pack and the also not compatible with security options.
