beezoluh
Nov 01, 2023Follower
Looking For Something Similar
I purchased the AC1900 USB for my PC since it doesn't have anything for a wi-fi connection and it has been great! There's no lag and great connection speed. My boyfriend is looking for something s...
michaelkenward
Feb 15, 2024Guru - Experienced User
beezoluh wrote:
My boyfriend is looking for something similar that can be plugged into a PS5 to help receive the wi-fi signal and make it strong.
Netgear's USB adapters are for Windows PCs and some Macs.
Look elsewhere to find something for a PS5.
Doesn't this have wifi built in?
Even if a plug-in wifi adapter did exist, it would probably hit the same brick wall.
If the wifi isn't strong enough to support that, look for something that improves the wifi.
We've tried the extenders, powerlines, moca things, etc etc.
Maybe you need a better one of those. Hard to tell without knowing what you tried and failed with.
