Neil_Con
Oct 15, 2017Aspirant
Lost installation CD
I purchased the above router many years ago, and just recently decided to try using it again. The only problem is i cannot find my resource cd, and cant set up the router. Is there a link to the relev...
TheEther
Oct 15, 2017Guru
Routers don't really need installation CDs. You can configure them with a web browser. Go to support.netgear.com and type in the model number. You can download the online manual which will contain instructions on setting up your router.
Neil_Con
Downloaded the manual, but it says i need to set up using the set-up wizard (which if i recall, was on the resource cd)
- michaelkenwardOct 16, 2017Guru - Experienced User
You haven't said which device you are using – I see no "above router" – but most manuals will tell you how to do a manual setup.
The quick start/installation guides are less helpful on that front.
For more advice, tell us the model number on your device.
