gnbalbion
Oct 30, 2015Aspirant
MediatekSw Application Crashes Daily in Reliability Monitor
Hello,can you please help me on this one, I am running the Netgear A6210 USB Adaptor on my Intel based PC. The USB Adaptor MediatekSw Application crashes daily. Do I need this application to be running on the A6210, if so can you suggest a fix for me please. Appreciate any help...thanks garry
Below is the printout of the Problem from the Reliability Monitor
Source
Summary
Stopped working
Date
30/10/2015 8:52 PM
Status
Report sent
Description
Faulting Application Path: C:\Program Files (x86)\NETGEAR\A6210\NetgearSwitchUSB.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: NetgearSwitchUSB.exe
Application Version: 1.0.1.1
Application Timestamp: 54379850
Fault Module Name: StackHash_76b1
Fault Module Version: 10.0.10240.16430
Fault Module Timestamp: 55c599e1
Exception Code: c0000374
Exception Offset: PCH_B9_FROM_ntdll+0x0006919C
OS Version: 10.0.10240.2.0.0.768.101
Locale ID: 3081
Additional Information 1: 76b1
Additional Information 2: 76b1253de6368a34241f1ea1610933cf
Additional Information 3: 7764
Additional Information 4: 7764f006b024e6d5021a39e6b0873691
Extra information about the problem
Bucket ID: 188bf12997809ad65ca5eb270317b63a (107539537085)
- JamesGLNETGEAR Employee Retired
Hi gnbalbion,
If you have an option for disable it then you may do so. Try to use as well the driver from NETGEAR instead of MediaTek.
http://support.netgear.com/product/A6210
JamesGL
Community Team- gnbalbionAspirant
Thank you for the reply, I am using the Netgear Driver, maybe the mediatek came fom the prior installation, I will check further,, thanks
