SavorySalisbury
Jun 22, 2019Follower
My A6100 drivers fail after every reboot
After essentially switching computers while keeping the same hard drive, the driver has been consistently failing. Whenever I boot my computer the internet shows a connection but it doesn't work. In the command prompt using "ping google.com -t" it has a steady 13ms connection for 3 pings, jump to 500-1000ms for a ping then get a request timeout and start the process again. Eventually I figured out it was the driver so I uninstalled the driver then reinstalled the same one from the install folder and it works again until the next reboot.
I don't know what's causing this or how to fix it beyond this boot routine.
1 Reply
SavorySalisbury wrote:
After essentially switching computers while keeping the same hard drive....
A recipe for disaster.
Can you clean out all the drivers and USB stuff on the new computer?
