martingc
Oct 14, 2015Initiate
My A6200 wont turn on when i connect it to my computer
In March earlier this year I had bought a A6200 WIFI adapter for my schooling as my computer doesn't connect to their WiFi and it's a very technology based school. When I plug in the adapter straight ...
- Oct 14, 2015
Do you have the Windows 10 drivers installed? You can download them from http://downloadcenter.netgear.com/en/product/A6200#searchResults.
To be safe, uninstall the old drivers before you install the new ones.
TheEther
Oct 14, 2015Guru
- martingcOct 17, 2015Initiate
Thank you so much! It started working as soon as I plugged it in with newer version for my computer. This has been such a good help thank you!
