KippTheHorse
Jun 09, 2018Aspirant
My Adapter won't connect to my Wifi but will connect to others!
Around christmas time i purchased a wifi adapter, specifically the WNDA3100v3 and when setting it up i had received some problems but i had managed to fix them. 6 months later I started to notice whe...
michaelkenward
Jun 10, 2018Guru - Experienced User
This sounds like an issue with whatever you have plugged the WNDA3100v3 into. My guess is a Windows PC, but which version of Windows?
Do you have the latest software for the device? Find it here:
>>>> WNDA3100v3 | Product | Support | NETGEAR <<<<
We also don't know what the source of your wifi is. Some sort of router?
KippTheHorse
Jun 10, 2018Aspirant
Hi michael, ia m running windows 10 Pro and my Router is a virgin Hub 3.0 if thats anything. it connects to any wifi such as my 2 extenders but not the Modem itself, Thanks
- michaelkenwardJun 10, 2018Guru - Experienced User
As I asked earlier, do you have the latest software for the A6100?
- Blanca_OJun 18, 2018NETGEAR Employee Retired
Hi KippTheHorse,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
