ThaSlo1
Apr 30, 2018Aspirant
N-300 Wireless USB Adapter
How do I set my N-300 wireless adapter up using my S8, and connect to the internet? Does it only work with netgear routers?
michaelkenward
May 01, 2018Guru - Experienced User
What is an S8?
And what N-300 wireless adapter are we talking about?
- ThaSlo1May 01, 2018AspirantSamsung Galaxy S8. How many different N-300's are there?
- michaelkenwardMay 01, 2018Guru - Experienced User
ThaSlo1 wrote:
How many different N-300's are there?Ooh, several dozen in all. Maybe a half a dozen USB adapters.
N300 is an indicator of wifi speeds. Look at the label on the thing.
The Galaxy should connect to any wifi source. But who knows what your USB adapter is plugged into and what you are trying to set up?
- JamesGLMay 31, 2018NETGEAR Employee Retired
Hi ThaSlo1,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
