ThaSlo1
Apr 30, 2018Aspirant
N-300 Wireless USB Adapter
How do I set my N-300 wireless adapter up using my S8, and connect to the internet? Does it only work with netgear routers?
ThaSlo1
May 01, 2018Aspirant
Samsung Galaxy S8. How many different N-300's are there?
michaelkenward
May 01, 2018Guru - Experienced User
Ooh, several dozen in all. Maybe a half a dozen USB adapters.
N300 is an indicator of wifi speeds. Look at the label on the thing.
The Galaxy should connect to any wifi source. But who knows what your USB adapter is plugged into and what you are trying to set up?
