paulgureghian
Dec 12, 2017Aspirant
n300 mini wifi adpter cant detect 5ghz wifi network
it sees and connects to the 2.4 ghz network but not the 5ghz. the router is broadcasting the network and my other "n" adapters can connect. this is in windows and linux.
michaelkenward
Dec 13, 2017Guru - Experienced User
N300 is not a Netgear model number. It is a wifi speed indicator.
The usual reason why a device cannot see 5GHz is because it does not support it.
paulgureghian
Dec 13, 2017Aspirant
the model number is WNA3100M. the box says b/g/n and 2.4ghz. i see no 5ghz. i thought "n" was always 5ghz ?
- michaelkenwardDec 13, 2017Guru - Experienced User
Guess not. The manual says nothing about 5 GHz:
>>>> WNA3100M | Product | Support | NETGEAR <<<<
The technology has moved on a lot in the five years since Netgear released that device.
Problem solved?
You can buy a 5GHz equivalent for next to nothing.
