paulgureghian
Dec 12, 2017Aspirant
n300 mini wifi adpter cant detect 5ghz wifi network
it sees and connects to the 2.4 ghz network but not the 5ghz. the router is broadcasting the network and my other "n" adapters can connect. this is in windows and linux.
paulgureghian
Dec 13, 2017Aspirant
the model number is WNA3100M. the box says b/g/n and 2.4ghz. i see no 5ghz. i thought "n" was always 5ghz ?
michaelkenward
Dec 13, 2017Guru - Experienced User
Guess not. The manual says nothing about 5 GHz:
>>>> WNA3100M | Product | Support | NETGEAR <<<<
The technology has moved on a lot in the five years since Netgear released that device.
Problem solved?
You can buy a 5GHz equivalent for next to nothing.
