Geekmachine
Feb 03, 2016Follower
N300 wifi usb adapter wna3100-100ens
We have purchased a netgear N300 wifi usb adapter. We have been unable to get it to run with the software included. The software is the latest version 2.4. We tried uninstalling and installing an ...
JamesGL
Feb 10, 2016NETGEAR Employee Retired
Hi Geekmachine,
If you have purchased the device recently, you may return it first to the store where you purchased it.
When you plug the device, can you see a light lit up?
Can you check the device manager if you can see the adapter?
Do you get error message when installing it?
Please try to use other drivers.
http://downloadcenter.netgear.com/en/product/WNA3100#searchResults
