Ubuz239's avatar
Ubuz239
N300 Wifi USB adapter
The setup went smoothly until I tried to enter our password for our home network. I could not enter a single digit. So I tried pressing the button on the cradle as the Netgear genie instructed. It fo...
  • JamesGL's avatar
    Dec 13, 2015
    Hi Ubuz239,
    Are you trying to use the Genie software to connect to the network or the Windows utiltity?
    What is the OS version of your computer?
    What is the model number of your adapter?
