Pesof
Jan 25, 2018Follower
N300 WiFi USB Mini Adapter not detected on Windows 10
Have attempted to install the driver for this product on both a laptop and PC now. Each time it goes through the installation process until I'm instructed to plug in the adapter into my USB slot. I ...
- Jan 27, 2018
wrote:
I'm running Windows 10.
This device was designed in the era of Windows XP. Maybe it doesn't work in Windows 10. That happened to some of my adapters.
Are you using the latest version of the software?
WNA3100M | Product | Support | NETGEAR
How about a different USB port? If Windows can't see it, there's not much that the software can do for you.
michaelkenward
Jan 27, 2018Guru - Experienced User
