maxy
Oct 08, 2015Aspirant
N300 WiFi USB Mini Adapter not detected on Windows 7
Have attempt to install the driver for this product on PC now. Each time it goes through the installation process until I'm instructed to plug in the adapter into my USB slot. I do so, and it sits tr...
JamesGL
Oct 09, 2015NETGEAR Employee Retired
Hi maxy,
Welcome to Community!
To isolate the problem, try to connect it on a different Windows 7 computer. If the said computer detects the adapter then try to disable anti-virus or firewall on the computer that is not working.
JamesGL
Community Team
maxy
Oct 12, 2015Aspirant
Thanks a lot James...it worked once i removed the Zone alarm program from my computer. One more thing..if i reinstall Zone alarm once again..will the wifi adapter continue working?
