arthurjackson
Jan 02, 2017Aspirant
N300 WNA3100M Mini USB WiFi Adapter - system tells me I'm using wrong password
Have installed N300 on Win 7, connecting to a netgear router. All seems good but when I enter SSID and password and try to connect I keep getting the message that my password is wrong. It isn't, hone...
- Jan 22, 2017
well computer went off for repair for another reason and it comes back and accepts the passwrod
so works fine now ta :0
arthurjackson
Jan 19, 2017Aspirant
Hello James - thanks for getting back to me :)
I used the setup CD on Win 7 so I presume that's the Windows utility - not sure what the Adapter genie is. I get the same when I try to connect using Ubuntu.
The password is all upper case and is the same I use on my laptop, so I'm sure that's not it.
Puzzling.intit.
arthurjackson
Jan 22, 2017Aspirant
