Spartacus1204
Nov 30, 2020Initiate
N600 Wifi Adapter Not Working
Hello Community, I have an N600 USB adapter that isn't working since this most recent Windows update, OS Name: Microsoft Windows 10 Home, OS Version: 10.0.19042 N/A Build 19042. Is anyone experienc...
- Nov 30, 2020
Worked fine until a windows update borked it?
Have you tried uninstalling it through windows, rebooting windows, and then doing a clean install?
Nov 30, 2020Guru - Experienced User
- Spartacus1204Nov 30, 2020Initiate
I tried the "Reinstall/Update" option before doing a complete "Uninstall" from the Netgear Genie app in the Start menu. (Funny, I picked "Uninstall" and it gave me two choices.) The reinstall worked. I should've thought of that. Good suggestion. Thanks for your help!
- plemansNov 30, 2020Guru - Experienced User
glad you got it workin!
