whittni12
Feb 26, 2016Follower
N600 Wifi USB Adapter
Hi, I'm trying to install the WNDA3100v3 resource CD Driver. My computer is Windows 8.1 and I do NOT have a CD drive. I've been trying to figure out how to get this. On the directions it tells m...
JamesGL
Feb 29, 2016NETGEAR Employee Retired
Hi whittni12,
Here is the link for the support page of WNDA3100v3.
http://downloadcenter.netgear.com/en/product/WNDA3100v3#searchResults
- DUMar 14, 2016Aspirant
I have EXACTLY the same problem as the person you replied to. And your reply is completely unhelpful I'm afraid. The link you give just goes back to the page of the manual that says insert the resource CD or enter the code..... Where are the actual installation instructions please?
- JamesGLMar 15, 2016NETGEAR Employee Retired
Hi DU,
The link I provided is where you can download the driver for the WNDA3100v3 without the installation CD. Once you have downloaded it and you have used the drivers to install, it should no longer asked for the CD unless your computer has issues.
