Karli86
Apr 07, 2016Follower
N600 WNDA3100v2 connecting to smart tv
I have a Netgear N600 WNDA3100v2 and i would like to use it to set up the internet on my Soniq smart tv. If there is some easy guidelines on this or any sort of help setting it up that would be much...
- Apr 10, 2016
Hi Karlo86,
The WNDA3100v2 will only work with Panasonic Viera TV. Please check this KB article.
TheEther
Apr 09, 2016Guru
Smart TVs generally do not work with USB-based Wi-Fi adapters. If your Smart TV doesn't have built-in Wi-Fi, then you will need an Ethernet-based Wi-Fi adapter, like the WNCE3001. A range extender will also work.
- JamesGLApr 10, 2016NETGEAR Employee Retired
Hi Karlo86,
- JamesGLApr 13, 2016NETGEAR Employee Retired
Hi Karlo86,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
