gustavio
Jul 07, 2016Tutor
Need the (correct) Win 10 Drivers and Software for NETGEAR A6200-100NAS
Hello all, I just purchased this model from newegg.com but I can't find an "exact download match" for the correct Win 10 drivers and software. NETGEAR A6200-100NAS AC1200 WiFi USB Adapter ...
- Jul 07, 2016
-100NAS means it's a North American model. The drivers you found at http://www.netgear.com/support/product/A6200 should work.
TheEther
Jul 07, 2016Guru
- gustavioJul 07, 2016Tutor
Hi The Ether,
Thank you very much for your answer and proposed solution. It all makes sense now!
Cheers and thanks again,
gus
