gustavio
Jul 07, 2016Tutor
Need the (correct) Win 10 Drivers and Software for NETGEAR A6200-100NAS
Hello all, I just purchased this model from newegg.com but I can't find an "exact download match" for the correct Win 10 drivers and software. NETGEAR A6200-100NAS AC1200 WiFi USB Adapter ...
- Jul 07, 2016
-100NAS means it's a North American model. The drivers you found at http://www.netgear.com/support/product/A6200 should work.
TheEther
Jul 07, 2016Guru
gustavio
Jul 07, 2016Tutor
Hi The Ether,
Thank you very much for your answer and proposed solution. It all makes sense now!
Cheers and thanks again,
gus
